Relocate battery, this circuit breaker good?
I relocated my battery to my trunk, and I figured I should get an inline fuse, but saw this on ebay: (something like this, but not this one, it says up to 15 days just to ship out!)
http://cgi.ebay.com/ebaymotors/100-A...fAudioQ5fVideo
Seems better to have a breaker so I don't have to get those fuses. I'm just unsure about the quality and if it will actual work. Would the fuses just be better? Also, is 100amps good? How much does the starter draw on a stock CRX starter?
It's extended wiring and it's just sitting under my carpet, even with grommets and those rubber brackets to hold it in place it could still short out.
Yes you need a fuse, the fuse you use will depend on the gauge of cable you use, EG: 4ga=150A 2ga=225A, you should be using at least 4ga.
Use an ANL/WRF type fuse... http://staub.ca/catalog/partdetail.aspx?partno=P150WFI
Use this type of holder... http://staub.ca/catalog/partdetail.aspx?partno=CWFH
do not get them from a car audio shop unless you want to be gouged for "gold plated" or "platinum plated" fuses and fuse holders, [not enough gold or platinum on them to short circuit the dynamo on a firefly's ***] check your local car parts shop or electronics supply. 94
mahatma
Jul 24, 2006 06:05 PM
