EK problems, need help!
Old Oct 3, 2002 | 06:25 AM
Carlito Brigante's Avatar
Default EK problems, need help!
I have a 99EK B16a2 swap. The car was running fine but lately I have noticed that the car kinda throws a weird sound out the exhaust around 7-8200 rpms. It kinda goes pah pah bah not a loud sound, certainly not detonation but like a fart kinda. no smoke no nothing, other that this the car is fine.
fuel pressure is at 45 psi wot.
im thinking it needs a tuneup, ignition all the way around. what do you think?
Old Oct 3, 2002 | 07:25 AM
vtec69's Avatar
Default Re: EK problems, need help! (fiaddictedsi)
start with the simple option get a complete tune up and if thats not the problem have a good mechanic take a look at it
Old Oct 3, 2002 | 09:12 AM
Jackson's Avatar
Sounds like timing. Check your cam timing to make sure you are not off a tooth and check your ignition timing. Are you getting any codes?
Old Oct 3, 2002 | 09:15 AM
2camsaam's Avatar
Default Re: EK problems, need help! (Jackson)
timming? Check your plugs and distributor. Any detonation on the plugs?
hope this helps
Old Oct 3, 2002 | 10:20 AM
Default Re: EK problems, need help! (2CAMSAAM)
its definatly not the timing. i had the honda dealer actually service this for me. as for a tuneup, i think thats what it might be, i haven't changed the rotor or wires in about 30G miles.
yikes. i just wanted to make sure it wasn't nothing serious.
would you guys recommend the sci ignition or 6al? I already just bought the distributor cap, i need the rotor, wires and blaster 2 coil but i figure what the hell go all out on a REAL tuneup.
thanks for the replies, any other info is greatly appreciated.
88 EF Hatch
18
Sep 23, 2009 02:31 PM
atownturbo
May 20, 2009 07:08 PM
driftam1
20
Apr 30, 2008 09:21 AM
AllMotor12s
Nov 11, 2007 04:20 PM
wtc7676
Apr 2, 2004 12:16 PM
