brian crower stage 3???
Old Aug 9, 2011 | 04:35 PM
christmastree's Avatar
Default brian crower stage 3???
setup: b18a1 block
p30 pistons
stock ls crank and rods (all balanced)
gsr head
7lb fidanza
b16 lsd tranny
here is my question. are these cams going to be too big for my setup? i know that they are supposed to make more power up top but does that mean that i am going to lose it down low? also i am most likely doing new springs and retainers just fyi. i stumbled upon a set that a guy is selliong for cheap
CROWER CAM 63403
Old Aug 9, 2011 | 06:00 PM
93delslow315's Avatar
Default Re: brian crower stage 3???
il sell ya my blox type c cams for 300 there basically brand new used for about 400 miles and now im going back to stock need a reliably DD . it is recommended to upgrade springs and retainers but strongly suggested to use stock valves
and to answer your question i doubt you would lose any down low power if you did it would be so little you wouldnt even notice, but you would notice a gain through the mid-high rpm range
Old Aug 10, 2011 | 07:36 AM
well i came across these for 170 lol
Old Aug 10, 2011 | 07:51 AM
jdmcx's Avatar
if they art the same as the original crower stg III (63413) they will fit but be close for the pric i would buy them and clay the motor.
Old Aug 10, 2011 | 08:00 AM
how tight of clearence are we talking? cause i still have to deck my head
Old Aug 10, 2011 | 08:06 AM
also these are 63403
Old Aug 10, 2011 | 08:22 AM
kyden's Avatar
403s would be crower, not brian crower (not the same company)
Old Aug 10, 2011 | 08:43 AM
hmmmmm ok i didnt realize the 403s werent BC. ok well then has anybody ran these or have an opinion
Old Aug 10, 2011 | 09:14 AM
jdmcx's Avatar
crower stage 3 cams are 63413 BIG lobes and i forget the clearance but i do remember i did +6 on intake and -6 on exhaust
Old Aug 10, 2011 | 09:38 AM
i have done a bunch of research on them and back in the day everybody had problems with them breaking. now i dont know if they still have breakage problems but i am a bit worried. so does anybody know if this problem has gone away?
lsvtek
Apr 20, 2007 11:05 PM
FROSTDC2
12
Oct 29, 2005 04:55 PM
thehondaguru
Sep 25, 2003 07:07 AM
HybridHatchC1
Jun 6, 2003 05:52 AM
kidkutz
Mar 16, 2002 02:35 AM
