is nitrous safe on a stock d16z6?
Old Oct 3, 2002 | 06:19 AM
serious's Avatar
Default is nitrous safe on a stock d16z6?
i've got a z6 in my 90 hatch, and i've been toying with putting in nitrous just for very inferquent use. what shot is safe to use on a stock z6? can i go with a 50 shot and not have to worry about blowing my engine?
Old Oct 3, 2002 | 06:20 AM
EP3_05's Avatar
Default Re: is nitrous safe on a stock d16z6? (serious)
Yeah it is safe. Run a 50 shot and colder plugs. You could also use an fpr and turn up the fuel pressure to be on the safe side.
Old Oct 3, 2002 | 07:20 AM
serious's Avatar
Default Re: is nitrous safe on a stock d16z6? (91civic)
how low of a shot could i go with and still get some noticable power?
Old Oct 3, 2002 | 07:25 AM
EP3_05's Avatar
Just run a 50 shot...it is safe..anything lower imo is not worth it.
Old Oct 3, 2002 | 07:34 AM
serious's Avatar
any recommendations on a kit?
how much will a 50 shot affect the life of my engine?
Old Oct 3, 2002 | 08:55 AM
ngkplugs's Avatar
if ur going to run a 50 shot of nitrous on ur stock internals of couse it will have an effect on the life time of ur motor but it depends on howmuch u use it and so on i deff agree with not using anything more on a stock motor
Old Oct 3, 2002 | 09:45 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: is nitrous safe on a stock d16z6? (ngkplugs)
A 50 shot shouldnt even affect your internals in the slightest. I used a 70 shot on a Saturn for almost 2 years and i took it all apart before i sold it and it was in very good condition....no sludge at all. Just make sure you run colder plugs and if you go above a 50 shot then you need some sort of fuel management. I just used an AEM fpr and i would bump the pressure up a little before i went out if i thoguth that i would need it....you can leave it up if you want but youll run rich and use a little bit of gas....wont hurt anything though. I would HIGHLY recommend the NX kit....i used it and it worked great. One of my solenoids went out one time and i called NX and told them what had happened and they replaced it for me for FREE. Good product and great customer service = . Hope this helped.
Sean
Old Oct 3, 2002 | 06:36 PM
illusive's Avatar
Go with a computer controled kit like ZEX. 50 shot should be fine
8083tcman
Jan 16, 2009 11:56 AM
juanintec
28
Jul 16, 2008 06:00 PM
jwcrx23
May 8, 2006 10:49 PM
cisurfer1
Dec 24, 2004 03:11 PM
BME1986
Jun 16, 2004 12:16 PM
