HELP! A/C auxiliary fans not kicking on... car overheating
Old Aug 8, 2011 | 11:14 AM
soundquest's Avatar
Default HELP! A/C auxiliary fans not kicking on... car overheating
95 accord 4 cyl. Auxiliary A/C fan does kick on when I turn the car off and the engine is warm... but they don't kick on when the A/C is on. Car is overheating in stop and go traffic as a result. What sensor(s) are responsible for telling A/C fan to turn on when A/C is on? Also, does that fan have only one speed or does it have a low speed (on when low A/C is on) and high speed (on when high A/C is on)?
Really need some input on this ahead of our roadtrip on Wednesday.
Old Aug 8, 2011 | 12:14 PM
holmesnmanny's Avatar
Default Re: HELP! A/C auxiliary fans not kicking on... car overheating
Which fan are you referring to, the passenger side or the driver side ?
Old Aug 8, 2011 | 01:04 PM
soundquest's Avatar
The Auxiliary radiator fans, both (can't remember if there are 1 or 2, not my car).
Thanks.
Old Aug 8, 2011 | 05:39 PM
poorman212's Avatar
95 4 cyl....after the car is off, the right/pass fan will come on-I refer to that as the cooling fan.
Anyway, follow the LOWER hose to the t-stat housing. Once there you will see a two wire green connector to Thermo A. Remove that connector and jump the wire side of that (paper clip or what ever), turn the car on/pos II or running (AC off)- Do BOTH fans run?
Chanb0b
Jun 27, 2019 09:25 AM
ZillaG
May 5, 2013 12:38 AM
f22a1 ftw
Aug 7, 2010 04:57 PM
ShinotakuX
Dec 14, 2007 08:20 PM
Kashi
Apr 13, 2005 07:09 PM
