90 si jumps wen taking off.
Old Aug 8, 2011 | 05:14 AM
SPIKE'S91CIVICSI's Avatar
Default 90 si jumps wen taking off.
i always feel the car jump wen letting go of the clutch.at first i thought it was the clutch cable.so i change it and tighten it.ran fine for a bit but then it does it again.can it b sumthing simple or is the transmision gonna be gone soon.it also scratches gears so i have to change gears slow.thanks!
Old Aug 8, 2011 | 07:43 AM
DumpdEJ6's Avatar
I like the tuna here
Default Re: 90 si jumps wen taking off.
Check/change your transmission oil. It might be low, or the synchros might be going bad.
I don't know about the "jumping"...
Old Aug 8, 2011 | 07:50 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Jumping? How high? Seriously though, sounds like your mounts are shot... unless you can describe the problem better?
Old Aug 8, 2011 | 09:09 AM
its only when im takin off.ima check my oil too cause wen i changed my clutch sum oil leaked out the tube.did a half as job.but the mounts are good.
Old Aug 8, 2011 | 03:57 PM
JDpower's Avatar
It could be a few different things. When that happened to me it was my tps and my throttle body(bad jdm tps and a sticky throttle). Or it could be miss firing because you havent done a good tune-up in a while, or even you distributor is on its way out.
Old Aug 9, 2011 | 05:24 AM
makes sense a lil.it use to idle up and down but now it idle normal.may jus b a sensor.junkyard time!
jonyi27
Dec 28, 2012 11:43 AM
klnteg
Jun 18, 2010 05:37 PM
darkspector
Jun 2, 2005 07:24 AM
JCCOOL43
Oct 2, 2003 12:08 AM
freeplay
Sep 13, 2003 02:16 PM
