All motor B Series
Sup squad thinking of building a little n/a setup for the daily nothing to crazy.. But then it will be daily/weekend/track car..
I was thinking
b16 head pnp
skunk 2 pro series valve-train
skunk 2 pro series cam gears
skunk2 pro series manifold with jg 70-72mm tb
not sure about cams, but I was thinking skunk 2 stage 2 or maybe stage 3 if there not to aggressive( open to suggestions)
rc 450 injectors so it has plenty fuel to flow
b16 tranny cf synchros with gsr 5th and itr final drive with obx lsd
clutchmasters clutch with 8-10lb flywheel
aem fuel rail fpr with gauge
gsr block bored to 81.5mm
mircopolished gsr crank and balanced
rs machine 81.5mm pistons
brand new gsr oil pan & pickup
toda racing timing belt
all new gaskets
gsr arp headstuds
What do you guys think? I know most mike say go K but I don't wanna convert and do everything .. I have alot of B series parts and extra trannies so this is why I rather stay B.. So let me know what you guys think?
I was thinking
b16 head pnp
all new gaskets
gsr arp headstuds
pro 1 are nice if you can have them degreed if not go with the skunk2 tuner 2 stage 3 are def not for daily use although people will say you can but i wouldnt
and third the primaries on the tuner 3 are not like stock cams just because it says tuner dont under estimate the size of the cam
i two things i would change on your build would be stick with a gsr head and run p30/pr3 pistons. between these two parts you will gain at least .5 to .7 comp over an itr piston/b16 head set up.
second about your cams, the stage three skunks might be too big. oh im sorry "tuner three" i was just responding up top to the guy saying they cant be daily driven. i say go with some allmotor cams or if low on funds some skunk stg 2 or pro 1. you might have enough motor for the pro2 but im not all too familiar with the pro cams besides a pro 1
for one unless your reving to 10k rpm and higher its pointless plus from his setup he posted it wont have the compression to really benefit from those cams
Really gsr head over the itr head? But since the b16 head flows so well, that's why I went with that over the gsr.. And I can't change the block setup because it's already built I'm actually thinking about buying my buddy's built block and those are the specs of it.. But I get what you saying, if I was doing this from the beginning I probably would have done what your saying..
Thank you all for the feedback , helps me out alot..
Also he was building this motor for alot of nos because he was gonna use that block with a worked b16 head ,skunk 2 manifold, aem fpr and fuel rail , 450 rc injectors, 68mm itr tb, and etc
Lets say 5k because if it ended u being more I would just get a k swap 2000-2500 and the k series package for 3k and have a tuned 230-245 monster.. Rather spend that money on a k then a b and still be reliable with bolt ons and pretty quick car
Ahhh see I didn't even think about that .. Thanks man good idea
Who has spent that amount on a k-series swap? From everything that I have researched, they get way pricey. I would stick with what you have and run Skunk 2 Stage 2's. Depending on what you want for mid-range, the stage 2's would be just fine. What compression are you looking at? Did I miss that?
Im thinking the same thing?
JDMSINGLEBOOSTED
Jun 7, 2007 08:39 PM
