what is the [whistling] noise at high rpm b20v?
Old Aug 8, 2011 | 12:25 AM
Corksil's Avatar
Default what is the [whistling] noise at high rpm b20v?
Hey i have b20vtec. b16a3 del sol vtec head.
when i rev up super high I hear a strange noise... it sounds like something is whistling, and if i shift as soon as i hear the noise, it sounds liek a blowoff valve.
i have plenty of oil/vtec fluid... nothing wrong with the car whatsoever. everything is rebuild and new components and running perfectly.
it happens around 6500rpm... i rarely rev that high but when i do i hear the noise in every gear.
let me know if you need to know anything else.
b20v naturally aspirated. b16a3 (94 del sol vtak head OEM)
Old Aug 8, 2011 | 08:05 AM
Corksil's Avatar
Default Re: what is the [whistling] noise at high rpm b20v?
bumpppppppppp
Old Aug 8, 2011 | 01:28 PM
Be2-SPEK's Avatar
I might not be right about this but by any chance do u have an aftermarket intake if u do that might be it I had a 3in. And mine did the same thing only thing was mine was a full b16 maybe this helps but not 100% just my 2 cents
Old Aug 8, 2011 | 02:05 PM
negusjuda's Avatar
the blow off valve noise i dont know but a intake manifold that has a vacuum leak will make a whistling noise does it run lean the vacuum leak will also make it run lean theck to make sure the intake mani isnt cracked or that there isnt any leaks i had a ls with a crappy intake mani that did this and it was cracked
korrupt3dazn
Mar 6, 2019 03:56 PM
ziggy3784
14
Apr 6, 2009 05:12 PM
HonBlackSol93
Oct 3, 2007 06:05 PM
pr0jectezek1el
Oct 22, 2003 07:04 AM
