Whored out Si Coupe.... some what... 56k be patient
ran a 15.0 with very, i mean very bad wheel hop.. it was like erf quake, and with the 16inch spoons. hopefully get some Z10s up front
HMM.. my good friend had same problem in his si, though he got the comp. eng. bars and they did not help much, from doing research into the problem i have come to conclusion that it has to do with front suspension and aligment! Cheap shocks up front (kyb, etc...) may be problem, and i also recomend getting camber corrected and front end aligment if your car has been lowerd!! good luck, eric
Khoi
Jesus...a C5 and only a 15.0? I bet your kicking yourself in the teeth now for spending 5k+ on that. Invest in a diet for your car. She's a piggy.
That looks extra smoof. If it was your first time at a track the 15 is completely understandable. Practice makes perfect.
Negative Camber = Wheel hop
Looks like every other so called "JDM" car. Wow
If I see another Civic on this board with Sw388s or Shitstreams im gonna yack!
Other then that dope seats and Nice ride! minus the CF hood.
[Modified by VSM SiR, 3:51 PM 10/3/2002]
why do people keep calling coupes "JDM"???? there ARE NO COUPES IN JAPAN!
and yeah, why bother buying an Si if you were gonna pull out a perfectly good b16 motor and throw in a B18C-R.... you might as well have bought an HX. HX is lighter too. but then again you might as well have bought a hatch. to each his own..
and to everyone surprised at 15.0 - that sounds about right. the coupe aint light.
. the coupe aint light. ,
thats pretty lightNo coupes in Japan??? WTF are you saying
http://www.honda.co.jp/HOT/ModelData...302/index.html
http://www.honda.co.jp/HOT/ModelData...601/index.html
[Modified by VSM SiR, 3:57 PM 10/3/2002]
2606 lbs is lighter then an ITR
thats pretty light
