Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Honda Civic sputters and all the lights din
Old Aug 7, 2011 | 01:43 PM
rayboren's Avatar
Default 2001 Honda Civic sputters and all the lights din
My 2001 Honda Civic is starting to sputter while im driving, and all of the lights wil dim at the same time. The head lights, the dash lights, and the dome light if its on. Then after a few minutes it will stop. Sometimes it will go on for a half hour, sometimes it will last for 10 minutes. Any clue? Thanks everyone.
Old Aug 8, 2011 | 02:15 AM
shawnlee250's Avatar
Default Re: 2001 Honda Civic sputters and all the lights din
Is the battery light is on? It probably be a lose wire or a weak battery I say. Go to autozone and test out the battery volt meter. If the car not on, the volt should be at 12.5 if it running the volt should be 14+
Let the car run and check the volt meter. Then turn the headlight on and fan on. If it drop below 12v I think the battery is going bad.
Old Aug 8, 2011 | 02:24 AM
new_game88's Avatar
10 Year Member
its probly a ground problem
Old Aug 8, 2011 | 03:46 AM
K24_Y61P's Avatar
Alternator / battery
homero
Apr 4, 2012 10:39 AM
that_boy_sammy
May 18, 2011 04:55 PM
justinwebb
Mar 9, 2009 11:45 AM
NOFX
17
Mar 25, 2008 12:17 PM
Buckshot
Dec 12, 2002 08:11 PM
