Toda Spec B's, ITR w/ CTR Pistons
Old Aug 7, 2011 | 11:51 AM
AllMotorDan's Avatar
Default Toda Spec B's, ITR w/ CTR Pistons
Im running Toda Spec B's in my JDM ITR with CTR Pistons. I'd like to know if anyone else has ever ran a similair setup and did they clay the engine or adjust the cam gears at all? theres really not much info regarding peoples builds with toda cams on the internet.
Old Aug 7, 2011 | 01:03 PM
kyosoeg6's Avatar
Default Re: Toda Spec B's, ITR w/ CTR Pistons
well before somebody jumps in and flames away, although there really isnt much info on toda cam usage , there is info on ctr pistons. its pretty much a no no due to the high dome . some people will swear they have never had problems running cams with them and others will say they dont last but a few xxxx miles. my only experience with these pistons was in a gsr block gsr head ctr cams. motor still runs but not abused much.
BTW: i wish my grandpa was as cool as yours.
Old Aug 7, 2011 | 01:33 PM
thanks, im not asking peoples opinions on my build. im simply trying to find out if anyone out there has had a similar build and if they adjusted the cam gears. i dyno'd the engine and the cam gears were set to 0,0 and it only put down 175/122. i know theres more potential from the cams but im starting to think im better off throwing stock itr cams back in and using them to there full potential.
Old Aug 7, 2011 | 01:50 PM
Uncle Dave's Avatar
Cam degreeing will make more power with that setup we are just waiting for Toda to send the true cam card for them so I can post it up in another thread.
Old Aug 7, 2011 | 02:16 PM
when is that expected? i want to adjust the cam gears i just don't want to run into piston to valve clearance issues. i understand the only true way to do this is clay the engine
my setup btw,
Stock JDM ITR Block with OS CTR Pistons
Stock JDM ITR Head with Toda Spec B cams, Toda Springs, Toda Cam Gears, Toda Timing Belt, Toda Header, Stock Head Gasket, RC 310 injectors, Spoon Throttle Body, Stock Intake arm with Spoon Filter.
Old Aug 7, 2011 | 04:14 PM
kyosoeg6's Avatar
I'm not too familiar with cam degreeing but can't you degree without a cam card?
Old Aug 7, 2011 | 05:28 PM
00Red_SiR's Avatar
All Motor Mentor
No, because it's the cam card that gives you the specs that you degree the cams to, or at least the specs that you verify your measurements against.
Old Aug 7, 2011 | 05:46 PM
90efhatch's Avatar
Post #99 has the Toda B cam spec sheets.
https://honda-tech.com/forums/showth...2458563&page=4
Old Aug 7, 2011 | 10:11 PM
TheShodan's Avatar
Moderator
I've got the true Toda B Cam card here.
I'm sorry I was not able to help much. I did make 207whp / 140ft/lbs of torque on my engine. The key was to properly degree the cams on installation, and then adjusted the gears to about 1+ intake 0 exhaust, while the tuner did the rest on Apex'i Power FC
Here is the Toda Spec B cam card. Toda Bs are a great camshaft, but they need to be properly degreed by the cam card before you dyno, otherwise, you get no results.
Intake CAM
Exhaust Cam
Old Aug 8, 2011 | 01:09 AM
Uncle Dave's Avatar
Shodan nice work I will keep chasing my Toda mate here in Australia for the Spec-C sheet then
Old Aug 8, 2011 | 11:40 AM
Slaz's Avatar
Pretty sure you'll find its also 105 at TDC on both of them.......
Old Aug 8, 2011 | 01:57 PM
soupE__'s Avatar
Ya just gotta be JDMMM and run a CTR piston man
Old Aug 8, 2011 | 03:00 PM
Super JDM dude!
totsie7944
Sep 23, 2005 03:01 PM
Aceman64
Aug 29, 2003 02:11 PM
Aceman64
Aug 27, 2003 05:57 AM
Aceman64
Aug 26, 2003 11:20 AM
