Can you Tell me what this is (was a sensor?)
Old Aug 7, 2011 | 09:49 AM
Not2farFromtypeR's Avatar
Default Can you Tell me what this is (was a sensor?)
Not sure what it is.... but im wondering if it's the cause of my car over heating.
Also I'm wondering if perhaps my ECT sensor is my problem. (thats located under the dizzy correct?) How do I go about checking if that's bad?
Old Aug 7, 2011 | 10:13 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Can you Tell me what this is (was a sensor?)
http://www.google.com/search?q=vtec+...w=1508&bih=790
Old Aug 7, 2011 | 11:18 AM
Does that mean that my vtec isn't engaging? Also could that be making my car over heat?
Old Aug 7, 2011 | 11:48 AM
The Grumpiest
Why would a VTEC pressure switch not being installed cause you car to overheat? Have you diagnosed anything pertaining to the cooling system itself? Radiator? Thermostat?
Old Aug 7, 2011 | 12:10 PM
That wasn't my doing. I bought the car in this condition. My question is could that effect it? It isn't he rad it was presure tested. Thermo checks out because I removed it to make sure that wasn't the case. No coolent in my oil and a compression test showed 135, 130, 145, 140. Which is about normal with eagle rod/vitara piston combo (7:5:1 compression)
Old Aug 7, 2011 | 12:16 PM
The Grumpiest
Maybe you're not understanding my statement. The VTEC pressure switch has nothing to do with the cooling system.
You're boosted? You really should provide all this info up front, like, in the first post. Possibly your rad is not up to the task or you have insufficient airflow. What did the previous owner say about the overheating and pressure switch?
Old Aug 8, 2011 | 05:00 AM
kyden's Avatar
is it only overheating under boost?
chris89
Dec 8, 2015 02:26 AM
Jdm John
14
Jun 19, 2011 04:24 PM
smileydub
Jul 3, 2010 07:38 AM
prelude-bb3
Jul 25, 2004 11:42 PM
See Are X
Feb 19, 2003 05:59 PM
