IACV housing air leak causing high idle???
Old Aug 6, 2011 | 10:54 PM
pcguy760's Avatar
Default IACV housing air leak causing high idle???
If my IACV has a small pinhole air leak on its electrical connector housing, can it cause my idle to go high as 2000rpm??? I used a spray bottle with soap water and it was bubbling like crazy on the connector housing and I found a (small) leak!
You cannot even hear the leak because its sooo small but it sure blows bubbles lol. I was wondering if some jb weld epoxy around the housing would fix it? What do you guys think?
Old Aug 7, 2011 | 02:19 PM
pcguy760's Avatar
Default Re: IACV housing air leak causing high idle???
Nm thats what it was ... whats this I hear about bypassing the coolant lines to the IACV if you have an hondata im gasket so it lowers im temps??? Came across quite a few topics about this - now it got me wondering lol ...
soggycu2
Jan 26, 2011 08:36 PM
joethejoeman
Oct 13, 2006 05:08 PM
c for sea
22
Sep 19, 2006 11:02 PM
huge230
May 12, 2006 02:00 PM
1badda
18
Jul 1, 2004 08:02 PM
