car takes a long time to start
Old Aug 6, 2011 | 07:47 PM
mish__'s Avatar
Default car takes a long time to start
when my car sits out for a day or sits out for a while it takes very long to start.
my battery is good.
took my starter to autozone to check it out and the guy said it worked fine.
but, i don't know why it's doing this.
i sit in my car, step on the clutch and try to start it and the radio will turn on along with the lights just fine, but i'd be sitting there trying to turn the ignition and it just clicks, most times i'd have to keep trying 20+ times, then it'll start. it doesn't crank, no grinds either. just click, click, click... till it wants to turn on.
any ideas?
Old Aug 6, 2011 | 08:58 PM
civickiller's Avatar
Default Re: car takes a long time to start
fast clicks ar one time, or one click with each try ?
Old Aug 6, 2011 | 09:00 PM
mish__'s Avatar
one click each try
Old Aug 7, 2011 | 09:31 AM
exb18c1's Avatar
my battery is good.
any ideas?
you have to check if the starter get the battery voltage ,and not consuming too many Amps.what do you mean by the battery is good?How did you tested it?
Old Aug 7, 2011 | 02:28 PM
mish__'s Avatar
my battery is fairly new.
Old Aug 7, 2011 | 02:34 PM
Drive 4 fun's Avatar
Batteries can be bad from the factory, though not common. Check your battery voltage with nothing on. Leave a volt meter on it and turn on the headlights and check the volts, and then, off the lights and look at the volts when you try to turn the starter over.
Old Aug 7, 2011 | 02:36 PM
mish__'s Avatar
so, you think my battery can go bad after a couple months of it working well?
Old Aug 7, 2011 | 02:41 PM
Voltmeter and end the battery question. Can it go bad, yes, but did it?
Old Aug 7, 2011 | 03:56 PM
Blown90hatcH's Avatar
Is the car stock?
Old Aug 7, 2011 | 04:51 PM
exb18c1's Avatar
Put the multimeter on the battery posts and have someone crank the motor the voltage shouldn't go lower than 9.6V.Make sure before everything to mesure the battery voltage.It should be not lower than 12.4 V.Do those things first.
Old Aug 7, 2011 | 05:12 PM
FlewByU352's Avatar
AEM standalone's are fun to start, just saying lol. There's no quick get away if the car is off even with the quick start thing.
Old Aug 7, 2011 | 05:41 PM
If you don't know what you are doing, then it might be a challenge. But starting a car with AEM should be perfect if you know what you are doing. The OP didn't say anything about an aftermarket engine management, that's why I asked.
Old Aug 7, 2011 | 05:45 PM
clean grounds with wire brush
i think bad starter solenoid
alot of people getting that recently
Old Aug 7, 2011 | 10:29 PM
try this
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/
EjSex
Aug 17, 2007 08:20 PM
nighttrain33
10
Feb 25, 2007 08:10 PM
andyep3
Jun 1, 2006 06:42 AM
tommymoose
May 18, 2005 03:40 AM
Jet Black
Sep 10, 2003 07:07 PM
