Oil light stays on but oil is full?
Old Aug 6, 2011 | 01:10 PM
garthjenkins's Avatar
Default Oil light stays on but oil is full?
Hey my 91 civic hatch with a d16a6 has the oil light on and it wont go away
the oil is full
whats up?
Old Aug 6, 2011 | 01:17 PM
KINGVEM^^ED6's Avatar
Default Re: Oil light stays on but oil is full?
Could be the oil pressure plug on the back of the block?
Old Aug 6, 2011 | 01:35 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Nothing is up really, just browsing the World Wide Web.
1.) Your oil pressure switch could be bad/ have a blockage.
2.) Your wiring could be faulty.
3.) Even if your engine is not knocking yet the bearing clearances could be so bad you are losing oil pressure severely.
4.) Your oil pump is failing (clearances).
5.) Your oil pump sump is clogged.
Put a mechanical gauge on it and see what your oil pressure is. Simple as that, then go from there.
ricky28
May 12, 2014 03:38 PM
TORTUGA
Oct 28, 2013 11:32 AM
Schultzie
Jul 10, 2010 08:58 PM
lonewsome
Jan 1, 2009 01:42 PM
xlee08
10
Apr 1, 2008 02:00 PM
