IACV - is it broken, how to test?
Old Aug 6, 2011 | 02:00 AM
gorsey's Avatar
Default IACV - is it broken, how to test?
I had a iacv error code and so its off and been cleaned. Before refitting I wanted to test it was working corrected. The wires for it from the loom had been damaged so I wanted to double check.
Accross the IACV the resistance is 13.5 ohms. I think this is within tollerence? between 8 and 15?
With the ignition on im getting 11.5v on the plug. However the valve at this point doesn't seem to open. I would have expected with voltage it would open - closed with none.
Apparently you should hear a click when the voltage is applied?
Old Aug 6, 2011 | 04:46 AM
Former User's Avatar
Default Re: IACV - is it broken, how to test?
You need to ground the IACV wire going to the ECU and then listen for the click.
Old Aug 13, 2011 | 06:09 AM
gorsey's Avatar
I've tested and works good. cleaned it and put a new gasket on it.
Refitted and same error 14. Been searching around and cannot find much. Thinking of testing another ecu? Any one know of things to look at before I do this?
Old Aug 13, 2011 | 06:17 AM
exb18c1's Avatar
Test the wires going to the ECU.
Mr. LS VTEC
Oct 15, 2014 05:51 AM
drbenne
Jul 23, 2014 08:57 PM
holmesnmanny
Dec 18, 2011 12:51 PM
joshy
Nov 26, 2008 04:50 AM
mywintercar
Sep 25, 2008 07:53 AM
