Installed TYPE-R intake manifold bad idea now..
Old Aug 5, 2011 | 03:10 PM
MainStreamHonda's Avatar
Icon2 Annoying idle issue, can't figure it out read current post
So I installed a Type R intake manifold on my '04 rsx. The idle was going from 1000 rpms to 3000 rpms while driving with the clutch in. Then a idle it was 1000 rpms to 2000 rpms. I switched back to my stock intake manifold thinking something was wrong but the same problem is still present.
I had a friend with a eg civic that had he issue and they by passed it, I like to solve problems and get things working correctly.. Incant think of anything that could have been messed up. I am stumped on this one. There are no vac leaks the coolant lines to the iacv are hooked up correctly..
Old Aug 5, 2011 | 03:19 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Installed TYPE-R intake manifold bad idea now..
First...and hopefully last.
Old Aug 5, 2011 | 04:07 PM
doood's Avatar
been there done that
sounds like a vacuum leak. your fault. not honda's.
Old Aug 5, 2011 | 08:02 PM
Sounds like your taking a stab at something you have no idea what your talking About.. A vac leak to the manifold with raise rpm not go up back down up back down, unless that vac line goes to a sensor..
Another thing uninstalled a strupt performance header the o2 sensor were moved down about 4 inches. So I had to extend wiring.. But I get 90 miles per 1/2 tank... So I am running rich and I have to check that on the scanner tomorrow.. Any knowledgeable input would be great.!!
Old Aug 6, 2011 | 07:32 AM
... No one?
Old Aug 6, 2011 | 12:10 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Sounds like you don't know what you are talking about either... A vacuum leak can cause sparatic idle up and down even if that vacuum leak does not fall on a sensor.
Do you have the right gasket. I'm not sure how the ITR manifold is but we put a RBC back on to a guys car after being supercharged and used the wrong gasket so it blocked his map sensor and we had a hell of time getting it to idle and run right and took us forever to figure out the issue.
If anything a vacuum leak is a good place to start. Grab some soapy water and start spraying looking for bubbles. Why did you go with an ITR manifold? I would have gone with an RBC.
Old Aug 8, 2011 | 04:55 AM
turboteg2nv's Avatar
That's a good way to get people to help you... considering you're the one who started the thread asking for advice.
Have you tried cleaning the IAC valve?
Old Aug 8, 2011 | 06:37 AM
I'm going to clean it first before I put the other one back on and look at tb gasket.
Old Aug 8, 2011 | 06:45 PM
jEromy's Avatar
Low coolant/Air in your coolant can cause this as well as make your car take way longer to heat up
Old Aug 11, 2011 | 02:14 PM
'Sprayed card cleaner no vac leaks.. also my car does not take long to heat up, but wouldn't air have worked itself out by now.. see the guy I bought this from told me it did it to his car before buying this from him, so I knew it could happen I am just trying to figure it out.
Old Aug 11, 2011 | 02:22 PM
These are the two holes and they are identical to the manifold I took off..
Old Aug 11, 2011 | 03:37 PM
sEaBRSXS's Avatar
hmm good luck
Old Aug 11, 2011 | 04:44 PM
jEromy's Avatar
On my old car, if there was air in the system , it never worked its way out. it may not be your problem, because it doesnt take an excessive amount of time to warm up...
Old Aug 11, 2011 | 09:24 PM
You said it never worked its way out, does that mean you had to do something to help it, or you changed back? Thanks for the info!
I truly do not think the manifold is crack or deformed. I will be taking it off tomorrow and inspecting it though.
Old Aug 11, 2011 | 09:54 PM
jEromy's Avatar
i had to bleed ,y coolant. there was a bleeder valve on the intake ( V6 acura legend) and you opened that, and then filled the coolant till bubbles came out, then coolant, that way you know there is no air in there. i couldnt figure out why my car was idling incorectly, jumping up 2-3k rpm, just like you described, well, it was because there was air inside my coolant. another side effect was my heater wouldnt work for the longest periods of time, because my thermostat wasnt opening because the air bubble was trapped up next to it.
sorry if the post is hard to read, ive had a long day
Old Aug 12, 2011 | 06:19 AM
No worries! Thanks man, ill look into this right now.
Old Aug 12, 2011 | 03:13 PM
Wasn't that, I replaced the intake manifold still no difference. the guy I bought it from said it took him a few cycles with the stock one before it went back to normal.
Old Aug 12, 2011 | 06:51 PM
CivicSi95's Avatar
sounds like the same problem i had on my b16a. i replaced it with a different throttle body and attached tps and problem went away
Old Aug 13, 2011 | 07:28 AM
Yeah.. I put my stock manifold back on the idle is screwy still ;/
The idle if driving goes from 1000 rpms to 3000 rpms. If the car is stopped it goes from 1000 rpms to 2000 rpms.. I think my iacv is messed up or something ..
Old Aug 13, 2011 | 11:40 AM
AnyOne have any suggestions new iacv?
Old Jul 20, 2012 | 09:02 PM
Wow didn't reply to this thread in over 2 years wow. Anyhow it was my IACV, it was stuck I took it apart lubed it up, everything worked great! I no longer have the RSX, but I thought (even though it has been forever) it would be nice to have a follow up!
Old Nov 24, 2012 | 06:42 AM
g35silversurfer's Avatar
glad you replied w/ answer! hate reading a good thread and all the way at the end don't find the conclusion lol.
BIGef
13
Oct 27, 2012 12:25 PM
97ej6dx
Nov 27, 2010 08:57 AM
macks97lude
Mar 2, 2009 04:28 PM
bong
Jun 12, 2001 02:47 AM
