Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Hondata Heat Shield gaskets Most in stock -- $50!!
Old Aug 5, 2011 | 10:16 AM
ChrisMillerRacing's Avatar
Default Hondata Heat Shield gaskets Most in stock -- $50!!
$50 shipped !!!! anywhere in the 48 states
Hondata have developed a special high temperature insulating gasket which replaces the stock intake gasket. This and bypassing several heat sources significantly reduces the transfer of heat from the head to the intake and incoming air giving you up to 5% more power.
Turbocharged cars often use an aluminum intercooler to cool the air compressed by the turbo. The intake manifold is also made of aluminum but because it is heated by the head from combustion and coolant, works in reverse to an intercooler by heating the intake air by as much as 50° C.
Fact: For every 3.3 °C (5° F) rise in intake temperature, air density drops 1%. The hotter the air, the less fuel the computer injects to compensate for reduced oxygen. HondaLogger datalogging software has enabled us to measure intake air temperature under varied driving conditions.
Around town, testing has shown an average drop of around 10 degrees C which is good for around 3 percent power increase. Remember though that 3 percent power increase is difficult to feel. You'd feel a greater change in performance getting rid of that passenger. In certain conditions a 30° C drop has been measured.
The Honda manifold is heated in up to 5 places. From the head, the interior heating takeoff hose, the cold idle valve, the idle control valve and the throttle body heater. The Heatshield gasket kit contains an insulating gasket, and installation instructions. A race version only version with the thermostat bypass blocked is also available.
Most kits instock ready to ship.
Old Aug 5, 2011 | 11:54 AM
Default Re: Hondata Heat Shield gaskets Most in stock -- $50!!
bump up to the top
Old Aug 6, 2011 | 07:23 AM
to the top guys!!
Old Aug 9, 2011 | 06:31 AM
bump up guys!!!!!!!!!
Old Aug 10, 2011 | 08:22 PM
bump up to the top!!
Old Aug 11, 2011 | 12:10 PM
Old Aug 12, 2011 | 06:43 AM
to the top guys!!
Old Aug 15, 2011 | 08:12 AM
bump up to the top
Old Aug 18, 2011 | 06:42 AM
PM's replied
Old Aug 18, 2011 | 12:45 PM
PM's replied!!!
Here's another bump for ya
Old Aug 19, 2011 | 07:10 AM
bump up to the top
Old Aug 22, 2011 | 08:27 AM
bump up to the top
Old Aug 22, 2011 | 01:59 PM
to the top!!
Old Aug 23, 2011 | 07:36 AM
Please call 631 465 0988 or e-mail us at Sales@GetPowerhouse.com to order!!
Old Aug 24, 2011 | 07:55 AM
Old Aug 24, 2011 | 10:46 AM
Old Aug 25, 2011 | 11:16 AM
Old Aug 26, 2011 | 07:17 AM
Old Aug 27, 2011 | 06:32 AM
Old Aug 29, 2011 | 09:53 AM
Old Aug 30, 2011 | 12:10 PM
thanks for all the orders! Keep them coming!
Old Aug 31, 2011 | 12:16 PM
bump up to the top
Old Sep 1, 2011 | 05:38 AM
September 1st here, hope everyone had a great summer@!
http://www.getpowerhouse.com
Old Sep 1, 2011 | 01:37 PM
to the top!!!
Old Sep 2, 2011 | 05:27 AM
All hondata in stock all the time!
