HELP!! d16y8 in a 1995 Del Sol running crappy throwing codes....
Old Aug 4, 2011 | 11:48 PM
juniordeniz_05's Avatar
Icon6 HELP!! d16y8 in a 1995 Del Sol running crappy throwing codes....
was praying a genius could help me solve my problem! so i recently dropped a d16y8 into my 95 del sol... the car is hard to start and revs poorly, it is throwing a code 6 (water temp sensor) and a code 9 (cylinder sensor)... the y8 came out of a 2000 civic ex... im using the b series 0bd1 harness (car used to have the b16 swap factory) with a ex tranny... dizzy is a y8 housing with z6 internals its got z6 intake manifold fuel rail and injectors with y8 exhaust manifold/downpipe... running a p28 ecu (chipped with stock p28 map)... everything is 0bd1... was hoping someone has been here already and can share some light on the matter... all sensors are plugged in... any help greatly appreciated...
Old Aug 5, 2011 | 01:15 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: HELP!! d16y8 in a 1995 Del Sol running crappy throwing codes....
Have you tried clearing the codes to see if they come back? Do you have access to another distributor? If so try any 92-95 non Z6 distributor and see if it clears code 9.
Old Aug 5, 2011 | 01:36 AM
strategy400's Avatar
Check the connector on the temp sensor. The wires break inside the insulation near the plug. My Honda dealer parts guy helped me rebuild the plug (disassemble/reassemble the plug with new blade contacts to crimp on the wire). The plug has a rubber circle pressed in it you have to pry out with a tiny screwdriver to let all the parts come out. They had the blade connectors in stock. The dealers are pretty good about stocking little parts like that (nuts, bolts, o-rings etc.) and prices are suprisingly reasonable. Plus there's hardly anyone in there when I go.
Aside from that maybe the B harness on a D engine is giving you issues.
Old Aug 5, 2011 | 10:26 AM
im not sure what dizzy will bolt up to that head?? and im pretty sure that if its a vtec motor doesnt it need a vtec dizzy? as for the temp sensor i will check it out again and see if i can find nothing wrong with it
Old Aug 5, 2011 | 10:43 AM
Technical Hero
Any 92-95 Civic except EX/SI/VX (D16Z6, D15Z1)
ef90honda
May 11, 2010 09:03 PM
sde780
Oct 13, 2009 04:54 PM
hoerter2158
May 13, 2009 10:55 PM
Arsenal
Nov 3, 2005 04:35 AM
Hatch_Back_97
Jul 23, 2004 01:57 PM
