Civic wont start...
Old Aug 4, 2011 | 04:32 PM
Elgrys.Mendez's Avatar
Default Civic wont start...
Hey guys, so the other day i came back from wal-mart and parked my car at home. Car was still running and before i turned it off the car turned off on its own. I have a kill switch connected in between the fuel pump and main relay. i tried cranking it back on and nothing. i switched ignition to ON position and the fuel pump is not whinning. So i replaced the fuel pump, nothing. Thought it might of been the Main Relay. Replaced it and nothing. What can it be? i did my research and someone told me about the thermostate housing ground maybe the issue or maybe a ground somewhere. PLEASE HELP....
Old Aug 4, 2011 | 04:54 PM
Wrona's Avatar
Default Re: Civic wont start...
can you stop makin multiple posts ktybye
Old Aug 4, 2011 | 05:00 PM
Not making multiple posts Wrona, the 1st one was deleted due to not specifing the problem...but thanks though
Old Aug 4, 2011 | 06:24 PM
ok to be more clear, just checked the car, on the ON position theres no clicking noise from the main relay nor do i hear the fuel pump whinning..what can it be? im going to check the grounds tomorrow and check the ECU if theres any error codes. Any other suggestions?
Old Aug 5, 2011 | 03:34 AM
ok so today i checked for battery voltage at the fuel pump connector...and come to findout its reading .70...maybe a short between the relay to fuel pump connector? please help
Old Aug 5, 2011 | 03:42 AM
deadbeatandrew's Avatar
it will be hard to determine the issue via teh interwebz.
try removing the killswitch, and start building it back from point A to point Z. more than likely it'll be an issue with the ks itself and how it's setup.
Old Aug 5, 2011 | 06:34 AM
thanks for the help h-t...car is running again
Old Aug 5, 2011 | 08:43 AM
Wrona's Avatar
wat was te problem??
Old Aug 5, 2011 | 08:54 AM
DO/\/\O's Avatar
post what the problem was... for next user's with the same problem
Old Aug 5, 2011 | 08:59 AM
tobebadtaz's Avatar
what they said, its nice to share info
Old Aug 5, 2011 | 09:08 AM
Hey guys, #24 Fuse was blown and ECU Fuse was blown...everything is good up and running now...so basically check your fuses 1st before going any other route...i read the Helms Manual and i read the key word "Battery Voltage" at the fuel pump connector, and since i found it odd that it only had .70 i checked the fuses and found the problem...btw i'll be starting a build thread shortly so u guys can see my 4 door in progress...it'll be a 56k in progress due to me being unemployeed at the present time but it'll be in the works...thanks again guys
Old Aug 5, 2011 | 10:53 AM
mrem1crew's Avatar
yea, I was gonna ask you to just check your fuses cuz that could be the problem. but seems like you got everything under control now. :D
Old Aug 5, 2011 | 01:18 PM
Yea that's the first thing I should of done, was already starting to stress since its my daily but it all worked out
Old Aug 5, 2011 | 01:22 PM
Cap'N Chronic's Avatar
I hate when I replace a bunch of supposedly bad parts..to find out it was just a blown fuse..
Old Aug 5, 2011 | 01:26 PM
Former User's Avatar
Good job solving the problem. Next time a little basic troubleshooting will save you some money.
civic08
Mar 14, 2010 09:26 AM
BBY98EX
Jul 20, 2008 12:06 PM
Jooleeus
13
Jul 20, 2008 08:46 AM
bogus_ek
Jun 4, 2004 10:18 AM
fastaccord94lx
Sep 5, 2003 08:50 PM
