Front End
Old Aug 4, 2011 | 02:56 PM
JTeel1781's Avatar
Icon2 Front End
Needing to know if it is possible to replace the Bulkhead on a 1990 civic dx hatchback myself? Any information is appreciated.
Old Aug 4, 2011 | 05:16 PM
rbwdriven's Avatar
Default Re: Front End
as in the front core/ rad support
or
the part where the vin is located on the back of the engine bay(firewall).
Both can be done.
Spot weld drill bit are your friends in both theories.
Issue is rear firewall is your looking at about 150+ spot welds plus removing all the seam sealer.
I'm doing that on my rhd conversion.
Old Aug 5, 2011 | 03:28 AM
JTeel1781's Avatar
I am just looking at doing the rad. support and headlight frames area.
Old Aug 5, 2011 | 03:30 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
If you have to ask it's above your skill level. Of course it's simple and easy to do; as with everything it just takes time...
Old Aug 5, 2011 | 07:14 PM
JTeel1781's Avatar
It is not above my skill lvl, i just like to do all my research before i do something. Sometimes u can find out little tid bits so u don't do the same mistakes.
Old Aug 5, 2011 | 09:09 PM
tonylovesjdmEF9's Avatar
dont worry about him he always has a negative coment bro and well its all about having the right tools and patience bro my friend and i did it before it took us a while to do it tho lol
Old Aug 6, 2011 | 10:42 AM
Canadian_EF's Avatar
well... i'll agree.... it isn't hard.... and there isn't really tips or pointers to give.... it's just work. work that won't get done unless you work on it.
As far as if it is possible or not, well, there are many people that have done it.
Old Aug 6, 2011 | 11:55 AM
rbwdriven's Avatar
get yourself a spot drill bit.
Will make it really easy.
you can pick them up.
just be careful to only drill through one sheet not both.
Old Aug 8, 2011 | 07:53 AM
JTeel1781's Avatar
Thanks for the info guys.
Wobbly_Jones
Feb 17, 2014 03:38 PM
HondaKid936
Feb 5, 2009 04:40 PM
Rust_si
35
Nov 6, 2007 09:37 AM
sihatchbackcivic1993
Nov 26, 2001 10:01 AM
