Transmission & Drivetrain Gearboxes, Differentials, Clutches
LSD vs non LSD
Old Aug 4, 2011 | 02:51 PM
93gsrhatch_1's Avatar
Default LSD vs non LSD
might sound stupid but what is the difference? because to me i still spin either way and it doesnt seem to be much of a difference the tranny is a S80 w/lsd.. anyone help me out?
Old Aug 4, 2011 | 03:04 PM
civickiller's Avatar
Default Re: LSD vs non LSD
for me, while i can spin 1 tire very easy. i have a harder keeping both tires spinning, this on street tires.
Old Aug 4, 2011 | 03:11 PM
Medinabard's Avatar
lsd better traction all year round...
Old Aug 4, 2011 | 03:22 PM
i agree there is a difference but just doesnt seem like much but i am on street tires as well and they still spin but i was just wandering someone's POV
Old Aug 4, 2011 | 03:35 PM
with my 2 step on the open diff was good, but with the lsd on the 2step, the car took off with very little spinning
Old Aug 4, 2011 | 03:42 PM
i dont have 2step and i try to launch at about 1500 or so but as soon as i go WOT the torque steer and tires are goin crazy
Old Aug 4, 2011 | 03:43 PM
i will be going to hondata s300 soon and hopefully i can see better results thanks for the .02
Old Feb 23, 2012 | 10:09 AM
NOSPNSRS's Avatar
Well, I JUST received my b18c (SiR-g) motor and it has the factory LSD, I'm more of a circuit kinda guy. So I'm hoping this does the trick for me.
Old Feb 23, 2012 | 10:29 AM
sc_at_QuaifeUS's Avatar
The bottom line is: with a LSD, you have twice as much traction vs. an open diff. because you splitting the torque between both wheels instead of one.
60 ft. times drop with a LSD.
Torque steer is greatly reduced with a LSD.
Passenger side front tires last longer with LSD...
The only 4 mods I can think of that would make you faster without adding power are:
LSD
Final drive
1-5 gear ratios
tire size (dia.)
Old Feb 23, 2012 | 10:50 PM
Mista Bone's Avatar
D Tranny Guru
Scott, if chassis and front wheels are equally loaded, a LSD isn't much up unless one wheel breaks loose.
25 cents of washers to change sway bar preload does wonders for traction.
HOWEVER you still risk the chance of exploding the spider gears....or twice like I did
OP, get your alignment checked. I don't care what LSD you have short of a spool if alignment is wrong you'll never get traction.
951kader
Feb 12, 2012 07:30 AM
rustydusty1717
31
Nov 2, 2008 04:08 PM
madmanmulligan
Feb 3, 2006 10:47 PM
CaliforniaHighwayPatrol
47
Jul 25, 2005 08:12 AM
IntegralGSR
Nov 9, 2001 03:48 AM
