Skunk2 throttle body
Old Aug 4, 2011 | 08:37 AM
Kyle Atwood's Avatar
Default Skunk2 throttle body
Alright I have an ek with an h22.
I was wondering if a s2 74mm TB will bolt right up to the stock mani.
Thanks
Old Aug 4, 2011 | 08:43 AM
hyperblu's Avatar
Default Re: Skunk2 throttle body
Thanks
You will more than likely have idle issues with a tb that big without upgraded cams and a tune.
Old Aug 4, 2011 | 11:52 AM
Hidenplanvew's Avatar
Waste of time and money... your stock TB flows more then enuff for as you have it... H22 in general flows alot of air stock
Old Aug 4, 2011 | 12:39 PM
Alright, so buying a bigger tb ATM is a waste.
Then what is the most beneficial upgrade I can do.
I got this motor from pic n pull, took it apart put a new head gasket on it and the usual replacements. It already has an aftermarket clutch, stock flywheel though, and a balance shaft eleminator kit on it. It is a jdm h22a, almost certain though it has an f22 intake/fuel rail.
Oh, and will the stock civic fuel pump give enough fuel?
Old Aug 4, 2011 | 06:36 PM
hyperblu's Avatar
If you want to free up the intake, get a port and polish on the head and intake manifold and a triple angle valve job
turboedsupe
Feb 28, 2009 06:45 AM
twiztid00002
Jan 5, 2008 06:09 PM
bb_one
Mar 31, 2007 03:09 PM
dc4teg95
Dec 8, 2006 08:08 AM
PearlCrx
Dec 20, 2003 12:41 PM
