Help! H22 halfshaft won't fit Jdm type-s block
Old Aug 3, 2011 | 07:23 PM
1slowcrx's Avatar
Default Help! H22 halfshaft won't fit Jdm type-s block
Swapped out my h22 for a Jdm h22 type-s n halfway through my assembly I notice me h22 halfshaft comPletely won't line up with the h22 block cus the casting looks different. What halfshaft to use or is there a bracket someone sells????
Old Aug 4, 2011 | 03:16 AM
SL0WEGG's Avatar
Default Re: Help! H22 halfshaft won't fit Jdm type-s block
What year h22 did you have? Is it the atts version? Type sh?
Old Aug 4, 2011 | 06:34 AM
1slowcrx's Avatar
Newer motor is SH aryle
Old Aug 4, 2011 | 07:22 AM
snobordboy's Avatar
Moderator
Yeah the type-s block has mounting holes for an ATTS unit, not a halfshaft. You need to make up a plate that bolts to the block and allows you to bolt up a halfshaft. There have been a few people who made some, and they may even have extras. Just poke around the Prelude forum, and you should find the info.
Old Oct 11, 2012 | 07:18 PM
HDeuceDeuceEj6's Avatar
I've ran into the same problem
op did you find a solution?
can anyone help?
Old Oct 12, 2012 | 03:35 PM
Old Oct 13, 2012 | 03:17 AM
mafia's Avatar
Is, you can make a plate (fab/weld) that will bolt up to the block then bolt up ur half shaft to the plate.
Old Oct 13, 2012 | 05:28 PM
1slowcrx's Avatar
Pm me. I have a custom halfshaft with plate I made for sale. Works like factory! Over 300hp and 1.6 60ft zero problems
Old Feb 27, 2015 | 05:06 PM
Eddie Huerta's Avatar
How much u sell that bracket for
MadTown
Aug 2, 2019 02:49 PM
Nonio
Oct 18, 2011 03:46 PM
LudePre1
Jun 6, 2007 09:16 PM
h22 civic
Mar 31, 2004 04:54 PM
RobBass
Jun 10, 2003 08:16 AM
