best front camber kit to use?
i have a 94 civic hatch lookin to put a front upper control arm camber kit full replacement in i want from where it bolts to the ball joint the car is a drag car and has around 850hp so i need somthing strong and somthing that will not come loose or wear out easy what is my best option to get?
ive looked into them but eveyone says there bushings are junk n ball joints so ive been lookin at this company spc im tryin to stay away from skunk2 alot of people have them n they seem to rust up fast and ive seen a couple people say the adjustable ball joint will move after time cause you can only get it so tight with the allen bolts
Yep, Skunk2 rear camber kit's are very well known to be extremely loud when hitting bumps. Squeaking, pops, etc.
I haven't heard any other issues besides that. My buddy had them on his integra and they made all kinds of noises. They were about a year old when the noise started.
Also, I haven't heard anything bad about buddy club camber kits.
I'm really glad I didn't waste $300-$500 on camber kits and alignments. Considering that they're ultimately worthless for daily driving.
Don't get one of those skunk2 ebay-knockoff ones. the actual part is fine but if you do, spend some money on replacing the bolts, as the iron arm is fine, the bolts and nuts are not, so I'd spend a few bucks on zinc coated grade 5 hardware.
MidwestSi
Suspension & Brakes
Mar 10, 2005 11:06 AM
Fuster_Cluck
20
Aug 4, 2003 08:08 AM
