D16Y8 - ECU has no power
Old Aug 2, 2011 | 06:29 PM
sab0521's Avatar
Icon6 D16Y8 - ECU has no power
I have a d16y8 the computer has no power starter radio windows all work. but the fuel pump is not. the original problem was a broke and deteriorated ground wire.
Old Aug 2, 2011 | 06:44 PM
Former User's Avatar
Default Re: D16Y8 has no power
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post. Title edited.
Old Aug 2, 2011 | 06:45 PM
Default Re: D16Y8 - ECU has no power
Check whether fuse 44 or 13 is blown.
Old Aug 2, 2011 | 06:51 PM
sab0521's Avatar
they are all fine put new grounds on everthing new battery cables tested ignition (key) for power all good main relay above the computer is not kicking on. and as for the post topic sorry im new at this forum stuff I couldnt even figure out how to make a post
Old Aug 2, 2011 | 06:56 PM
Use a multimeter to check whether terminals 2 and 5 of the main relay plug get voltage from fuse 44 and 13.
Old Aug 3, 2011 | 02:36 PM
sab0521's Avatar
13 doesnt work but im getting power to 7 in the relay so fuse 44 is ok
Old Aug 3, 2011 | 06:58 PM
You need to have the key in ON(II) when you test for voltage at terminal 5. If you did that, check whether fuse 13 has voltage to body ground at both top test tabs. Click the Test Fuses link in my signature.
Old Aug 6, 2011 | 12:45 PM
sab0521's Avatar
I have 12.6 at terminal 1 and no others
Old Aug 6, 2011 | 12:50 PM
Old Aug 7, 2011 | 04:14 PM
sab0521's Avatar
you already had me check that
Old Aug 7, 2011 | 04:16 PM
Please remind me what you found. What tests did you do and what were the results?
Old Aug 8, 2011 | 12:45 PM
sab0521's Avatar
im not getting any ignition power to the fuse box inside
Old Aug 8, 2011 | 01:51 PM
Default Re: ECU has no power
What test did you do?
Old Aug 8, 2011 | 05:06 PM
sab0521's Avatar
tested fuses but headlight horn locks all work its like the key isnt turning on I put a new ignition switch in
Old Aug 8, 2011 | 05:21 PM
Is 40A hood fuse 42 or 46 blown? Does voltage reach the ignition switch from the battery?
Old Aug 9, 2011 | 11:12 AM
sab0521's Avatar
im getting power through the switch switch tested fine
RacerRex
Honda S2000
Feb 12, 2015 09:14 AM
2ndthtsurplace
48
Sep 2, 2011 12:45 PM
Noldogg
Nov 1, 2010 09:02 AM
boostedtwo
Aug 17, 2008 08:18 AM
