Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
S2000 Oil Filter
Old Aug 2, 2011 | 05:45 PM
shawnlee250's Avatar
Icon3 S2000 Oil Filter
I seen quite few people done it when they change there oil filter, they used the s2000 oil filter. What the purposes of that other then bigger filter?
Btw I'm a noob and would like to learn more thing.
Old Aug 2, 2011 | 06:38 PM
It Wasn't Me's Avatar
Default Re: S2000 Oil Filter
Better filtration, IIRC.
Old Aug 2, 2011 | 06:42 PM
BoostedBuggy's Avatar
A bigger filter allows for better flow of oil and will generally keep the oil cleaner. However, the larger filter alters the oil pressure by a few psi...
Old Aug 2, 2011 | 06:56 PM
That Make good sense. So you guys would rather recommend using bigger filter?
Old Aug 2, 2011 | 08:26 PM
toyomatt84's Avatar
Sanji
Unless your D17 is running boost, or has aftermarket internals with higher compression, it would be entirely unnecessary.
Old Aug 2, 2011 | 09:26 PM
MindBomber's Avatar
I use s2k filters, but I also use royal purple which most consider entirely unnecessary for an almost stock honda engine.
I drive my car HARD and that's why I prefer a high quality filter and oil. I waste a massive amount of money on my car, I might as well put some of that towards a somewhat useful purpose.
Old Aug 2, 2011 | 09:48 PM
Thanks for all the help and info : )
Old Aug 3, 2011 | 12:54 AM
theineffable's Avatar
The larger filter on our cars will cause oil pressure to be a tiny bit higher due to less pressure drop across the filter.
Anyone remember when early 90's Honda filters were the size of s2k ones? Now Honda recommends the small filter for everything (except s2k) including the old civics. I guess Honda considers the change in oil pressure to be insignificant?
I started using my s2k filters on my civic so I wouldn't have to stock up on two different sizes of oil filters. Actually the wix s2k filter is cheaper than the tiny civic size filter
nicholasellin
May 6, 2014 09:52 AM
duf2570
Apr 27, 2014 08:23 AM
JDM00SI
Jan 20, 2006 10:58 PM
HamiltonRex
Oct 10, 2004 07:00 PM
00pyITR
Dec 15, 2003 07:42 AM
