d16z6 head gasket help plz
Old Aug 2, 2011 | 04:00 PM
Beto760's Avatar
Icon2 d16z6 head gasket help plz
Hi so im currently prepairing to replace my head gasket on my 94 civic. so ive been researching and recently purchased a Haynes Manual.. now i found that some people dont dissasemble the rocker arm and camshaft.. but reading the haynes manual it says that i should dissasemble the rocker arm and camshaft.. Any who possibly has change a head gasket know if this step is needed..
Also ive seen a video on you tube where a old man ignores does steps and jus takes the head off.
Heres the link: http://www.youtube.com/watch?v=rRbrV...feature=fvwrel
So let me know what u think.
Old Aug 2, 2011 | 04:07 PM
BrothaSit's Avatar
Default Re: d16z6 head gasket help plz
i recently did a headgasket on a d16z you can remove the head without removing the rockers/camshaft but you have to remove the the rockers/cams IF you were to resurface the head.
Old Aug 2, 2011 | 04:18 PM
TheMechanic84's Avatar
If your skilled a HG should take u a hour and a half on a SOHC motor...maybe less if your awesome. disconnect the the header and intake manifold (id buy a replacement gasket for the intake manifold 5 bucks at pep boys) mark the time belt and cam gear remove the head studs and pull the head off. you may need a razor if the gasket is stuck on the old cyclinder head
Old Aug 2, 2011 | 04:21 PM
Beto760's Avatar
Awsome jus need a lil reasurance... and might take it to the machine shop if it looks warped. whole process doesnt look to hard. thx again
Old Aug 2, 2011 | 05:14 PM
pwebb0207's Avatar
you wont be able to tell if its warped just by looking at it. it needs to be checked with a straight edge and a feeler gauge. this is very easily done, given the tools.
headpot420
Dec 27, 2008 12:52 AM
twentytwocpb
46
Aug 9, 2008 12:23 PM
ujhonda
Jul 4, 2007 07:55 PM
Methane2k2
Dec 18, 2004 06:27 PM
Wes90civic
Jan 1, 2004 07:17 PM
