help!!! on vtec pressure switch bolt torque
Old Aug 1, 2011 | 11:17 PM
mibayaua's Avatar
Default help!!! on vtec pressure switch bolt torque
Wussup guys! My 1993 D16Z6 is leaking oil, coming from the vtec pressure switch, does anyone know the bolt torque? There are three 10 mm bolts to the side and three on top
Thanks in advance
-Mike
Old Aug 1, 2011 | 11:57 PM
civickiller's Avatar
Default Re: help!!! on vtec pressure switch bolt torque
just make it tight and if its still leaking then its the gasket
Old Aug 2, 2011 | 06:01 PM
mibayaua's Avatar
thanks civickiller, freekin' $22 bucks at the dealer for a small gasket, autozone don't even know what it is, o'reilly has it but sold with the rebuilding gasket.
Old Aug 3, 2011 | 08:25 AM
Accordin2me's Avatar
I believe its around 7-11 ft lbs
Old Aug 3, 2011 | 08:27 AM
slimx554's Avatar
I think the Haynes manual calls for about 5lbs of torque.
Old Aug 4, 2011 | 04:02 PM
mibayaua's Avatar
F@@@cKK,,,I over tightened the damn bolt, what do you guys use to fix the thread =(
trippsEF9
19
Dec 6, 2012 02:15 PM
nicanbeastfool
12
Mar 8, 2010 10:08 PM
shbrown
May 21, 2005 09:14 PM
wannagofaster
Sep 10, 2004 02:37 PM
