VTEC LEAK
VTEC LEAK
my vtec seemed to be leaking i removed it and took it apart somebody told me it was my gaskets and they looked fine to me if that isnt the problem can you place cilicon around it reattatch to stop the leaking????
Re: VTEC LEAK
-Put some high temp gasket maker and bolt everything to spec. I cant find the torque lbs for the vtec solenoid, but it has to be between 7-10lbs. They're little 10mm bolts.
Re: VTEC LEAK
you need to replace the solenoid gasket. the bolt will absolutely break if you put to much pressure. two of my solenoid bolts broke when i put it back on and i wasnt even using to much torque so be really carefull and make sure you dont cross thread the bolt when putting it back on
Re: VTEC LEAK
What engine?
EDIT: Roughly around $15-20...thats dealer price. i've had to get one before but i dont remember if i got it from the dealer or a local parts store. I do know that Napa had no clue what a "vtec solenoid gasket" was, though.
Re: VTEC LEAK
rovafa2002
23
10-12-2023 03:46 AM
trippsEF9
19
12-06-2012 02:15 PM
