99 Honda Civic DX Radiator Fan Switch
Hi,
my car was overheating mainly cause the raidator went bad. I replaced the radiator and also the thermostat. Everything went well for about 2 weeks then it started overheating again. I found out that the radiator fan was not working so I jumpered the two terminals to see if it was ok and it turned on like it should. A friend told me to change the radiator fan switch so i did and it worked great for 1 week until right now. It seems like the fan is not turning on again, I jumpered the two terminals and it turns on like it should.
Could it be that my switch keeps going out because I might have a short in the wiring? I say this because the cigarette lighter fuse keeps blowing everytime i connect something to it.
If any one has any suggestions I would appreciated it. Thank you!!
Did you bleed the cooling system?
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
thanks!
jacollins5
Honda Civic (2001 - 2005)
Sep 17, 2016 01:02 AM
alpinegroove
Oct 22, 2013 10:27 AM
