93 del sol back wheel bearing trouble.
Ok im trying to get the wheel bearing off the spindle and the wheel bearing came off but the bearing broke so now im stuck with the back of the bearing stuck on the spindle. i was told to cut it in half with a cut off wheel but i have no air tools here and i have no chisel either. What is another way to get this piece of bearing off the spindal. thanks James
4 1/2 angle grinder works great to cut a piece of the old race off and then it will pretty much fall off. Other than that you'll have to get a cold chisel. They don't cost much.
well after i took the dust shield off i took my pry bar and hit the end of it and the race started to come off and it cracked in have so its all fixed now. 104 degrees out side and im soaked in sweat. one problem down many more to fix down the road.
rexload
Jun 5, 2015 11:31 AM
