Accord 1992 Blower motor Problem
I went to the junkyard to replace my heater blower fan and resistor for my 1992 accord. At first the fan moved very slow and later it would not move at all unless I moved the blade myself first. Later the fan would not turn at all even if I gave it a push.
I went the junkyard and replace the fan and resistor again. The same thing happened again.
I suspect that the blower motor relay is the cause of the problem but I don't know the location of it. I did some research at Autozone and was told that The Blower motor relay was behind the kick panel. I looked underneath the dashboard but I cannot match any object with the picture of the blower motor relay I saw at Autozone.
Does anyone know where the kick panel is?
Its under-dash in the fuse/relay box area, drivers side. Its in the dash fuse block (not behind the fuse block access panel... it's up a little further, about 6 inches, it's the one in the middle) - Ohm test the two silver terminals too & check the manual.
wow, i had the same problem with mine. the fan wasnt coming on and i learned that if i hit it, it would come on. over time it finally quit working at all. so i bought a new blower motor. had it put in and now the a/c does not blow cold air. infact its barely "cool" at all. before the blower went out the a/c was like an icebox. i checked the freeon. its full. it just doesn't get cold or remotely cool. i have no idea on where to go from here.
jshomer
Jun 21, 2019 07:17 AM
