stripped motor mount holes what to do?
Old Aug 1, 2011 | 11:11 AM
sh!ft's Avatar
Who the fack changed my title?!
Default stripped motor mount holes what to do?
should i just put a heli coil in there or should i tap it for a bigger hole and drill the mount for the same size as the bolt?
Old Aug 1, 2011 | 11:45 AM
90efhatch's Avatar
Default Re: stripped motor mount holes what to do?
I have used heli coils before there but only on a stock motor. Not sure if they will hold if you have a more powerful engine.
Old Aug 1, 2011 | 11:56 AM
sh!ft's Avatar
you could say i have a powerful motor lol
Old Aug 2, 2011 | 06:28 AM
turtleman321's Avatar
....ok a picture of your motor doesnt really render your motor superdydooper.
i would weld up the original holes and drill and tap them again
Old Aug 2, 2011 | 06:45 AM
draggbody's Avatar
but its got a bling oil pan... must be good for 700 hp... lol
Old Aug 6, 2011 | 09:24 AM
black0hatch's Avatar
ive heli coiled them in the past. i once took the mount to a machine shop to get it drilled out for a larger bolt but they couldnt do it im guessing its hardend.
Old Aug 6, 2011 | 09:45 AM
sh!ft's Avatar
exactly^ thats the issue i was having with the shop i went to, they said to get a carbide bit. but every dam place i went to only had em for masonry.
this is what ive decided to do, i have my holes tapped for a 1/2 by 13 grade 8 bolt. im going to have my shop machine a portion of it off to 7/16's and then re-thread it. almost like an arp bolt but cheaper. i believe it will work because its pretty much the same aspect as using a regular bolt, but only its a stud with a washer and bolt instead.
letsgetit365
Jul 21, 2017 08:42 PM
Sean1992
Honda Civic (2006 - 2015)
Feb 2, 2017 02:25 AM
natovang17
Jun 18, 2009 08:44 PM
grog
Apr 25, 2008 06:44 AM
mkazm83
Jan 28, 2006 04:46 PM
