rear window to permanently stay up/shut
Old Aug 1, 2011 | 10:33 AM
the soL that could's Avatar
Icon6 rear window to permanently stay up/shut
i purchased an EG and the rear driverside window is jacked up. it remains half open and does not roll when i turn the level. i basically need this to stay shut permanently so rain does not get in... how do i do this?
Old Aug 1, 2011 | 10:37 AM
Former User's Avatar
Default Re: rear window to permanently stay up/shut
Remove the door panel and inspect. It sounds like you need to replace the window regulator.
Old Aug 1, 2011 | 11:10 AM
i have no idea what that is... i tried to do it myself and cut wires... probably did more damage than anything. it is a manual rolling door, by the way.
Old Aug 1, 2011 | 11:22 AM
Old Aug 1, 2011 | 02:18 PM
bandit67's Avatar
Here is what I did. If the system has not been to messed up, pull the panel , physically work the glass up and down and watch where the control wires feed out and feed into the roller. Slip off the plastic connection piece and pull in around to the outside window crank bolts. I loosened one of them up and slid the wires under that and locked the wires from moving. This kept the window up. Leave off the window crank. Found the same side door in the salvage yard a few weeks later and remove everything after checking it was working perfectly. Use those reprints RonJ posted and install the whole thing. RonJ post some excellent , invaluable drawings.
aznsyco
Jun 11, 2009 12:02 PM
Spence
Nov 24, 2006 08:05 PM
Mycroft Holmes
Mar 14, 2002 07:42 PM
