Best LCA's for EG
If price were no issue, what would you get , and why?
Should I get a set with spherical bearings? Are spherical bearings worth it? Or just stick to urethane?
In terms of functionality, durability/longevity. What are the best? function7, skunk2, buddyclub, PIC....just to name a few.
This is for a weekend car that will be drag raced and auto crossed, with a stff suspension.
Thx
Brian
Thx
Brian
I've had great luck with my OEM. But if you had to go aftermarket. Anything less than Function 7 is a waste of money that would be better suited if donated to me.
But seriously. OEM. Or Function 7 if aftermarket.
I'm glad to hear those held up well, I've recommended them for some time now.
Indeed OEM or F7 are going to be best. The cheapest but still good option I think is used OEM Integra LCAs with urethane bushings because it's only about $25-30 plus about $5 for some new paint to spruce them up.
Also... what other polyurethane bushings do you recommend I order while I am working back there? I am about to do a rear disc conversion + ASR brace + sway bar in the back. Sorry if this last question was off-topic.
Thanks!
^Look at these. http://www.energysuspensionparts.com...a+Integra+1996
OP, function7 is the ****, but stay away from sperhical's unless you plan to track the car. They normally do not last at all on the streets. And I don't belive they're covered by the F7 warranty.
For the money ES is a contender. BUT, the normally don't last very long, in some cases they do. But you will have clean them and lube them. This will prevent therm from failing and squeaking.
If you can afford it, take a look at PIC and hardrace bushings. I may end up going with a few ES bushings just to hold to me over. Trailing arm bushings are gone lol
Thanks for sharing bro.
Also, LCAs from an 89-91 Civic/CRX Si are a perfect fit on an EG, they can accommodate the sway bar, AND don't have the holes for the ABS lines, if you're picky about that kind of thing. This is what I have.
