85 CRX Carb/idle help
Old Jul 31, 2011 | 04:47 PM
269insane269's Avatar
Default 85 CRX Carb/idle help
the car will start, usually will go up to 2k rpms then drop down till it stalls unless you press the gas, there is new spark plugs, wires, distributor cap, distributor rotor. we still have to try out cleaning it with a carb cleaner, but idk if the carb gasket isnt sealing, or if it is a vacuum line, i dont see any crack vacuum lines.
Old Jul 31, 2011 | 05:34 PM
Default Re: 85 CRX Carb/idle help
also there is a gas tank leak, idk if that is what is making it do that, and it is spitting and sputtering.
Old Jul 31, 2011 | 06:28 PM
fcm's Avatar
fcm
Old Fart
Vacuum line is cheap, buy enough to replace all the vacuum lines on the engine, if for no other reason then to eliminate them as the problem, they are over a 1/4 century old, probably need changing anyway.
A propane or butane torch, even a BIC lighter can be used, [do not light] to see if the carb gasket is leaking, "spray" at gasket with engine running, if engie reves up, gasket is leaking.
The carb is 25 years old also, a carb kit and rebuild would not hurt. 94
Old Aug 1, 2011 | 08:50 AM
were going to get some carb cleaner, i heard u can use it to see if the carb gasket is leaking, plus were gonna see if the carb needs cleaning, but idk if the carb is making spit and sputter
Old Aug 2, 2011 | 09:49 AM
bump
269insane269
Jul 31, 2011 05:19 PM
Mr.DXt
Jan 13, 2010 08:27 AM
skater5067
Apr 22, 2005 08:24 AM
morepoop4u
Jun 30, 2002 08:15 AM
GruvyTune
Jul 30, 2001 12:44 PM
