ls swap into 91 civic hatch
so i have a 91 civic hatch and a automatic 90 teg and i want to swap the b18 into my civic. right now i have manual tranny with converted shift linkage and a manual ecu for the b18. what else do i need? what should i get other than the clutch. i know i need to do some wiring to convert it from dpfi to mpfi but idk how. since i have the teg can i use pretty much everything and swap it to my civic? This is my first swap so i really would appreciate the help! thanks!
1. 90-93 teg axles with manual half shaft. auto half shaft will not work. 2. Also need the rear t braket from 90-93 teg must be manual again auto one will not work. 3. Also need motor mounts made for the b series swap in the ef plat form civics/crx
All the information you seek is in the link below... Some of the links are broken for the information you seek, but keep clicking them until you find one that works. Searching is your best friend...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
stackz
Nov 9, 2006 06:44 AM
