want to go obd1 need help
Old Jul 30, 2011 | 07:02 PM
dracocrx's Avatar
Default want to go obd1 need help
i have a 90 hf dual point crx with no engin harness the car has a d16z6 in it what would be the best way to go obd1 do i need to buy a dual point engine harness and convert it to muilti point then convert to obd1
thanks for the help any info is helpfull
Old Jul 30, 2011 | 09:17 PM
JDpower's Avatar
Default Re: want to go obd1 need help
Explain HF duel point? Do you have an hf shell running a dx engine(with a dx cabin harness)?If so you would have to convert to mpfi(hf's are mpfi) then get a jumper harness and a p28 ecu.
Old Jul 30, 2011 | 10:45 PM
crx_si-r's Avatar
HF CRX's are NOT dual point they are multi point. All you need to do is find a stock harness (I can make you a stOck harness fully converted to obd1), obd1 distributor, o2 and ecu jumper. And your set to go after you wire up the obd1 parts.
THEhomelessONE
Dec 25, 2018 08:39 PM
simjosh
Apr 5, 2017 04:28 AM
MonKK
Jan 20, 2009 07:59 PM
nitroracer
Sep 9, 2006 07:50 PM
myEK=slow
11
Aug 21, 2006 08:20 PM
