Can't get oil pan out... rusted exhaust bolts...HELP
Old Jul 30, 2011 | 05:58 PM
koulninja's Avatar
Default Can't get oil pan out... rusted exhaust bolts...HELP
Specs: 1995 civic dx coupe
So my oil drain plug is stuck in the oil pan. I keep turning it but it won't come off, it just keeps turning. Now I bought a new oil pan and gasket. Theres a pipe between the exhaust manifold and exhaust itself that needs to be removed in order to get to the oil pan. Problem is the nuts holding that curved pipe is rusted and one nut is rusted completely.
Should I just cut the dang things off and replace the the nuts and bolts? Or is there an easier way to do this. I hate MN winters its like cancer for cars.
Old Jul 30, 2011 | 06:51 PM
appelsos's Avatar
Default Re: Can't get oil pan out...HELP
try pb blaster, let it soak in for a day or so. if you still cant get the nuts off even with a breaker bar, you could try those damaged bolt remover sockets. they essentially cut into the bolt itself to get it off- they've always worked great for me.
if not, yes, cut the bolts off at the stud and buy new ones.
Old Jul 30, 2011 | 06:57 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
You always heat up exhaust bolts before removing them when you live in the rust belt. Buy a $30 MAPP gas torch. It'll be the best $30 ever spent. I usually hit the bolts with a bit of heat for a while and they come off like butter.
Old Jul 31, 2011 | 07:12 PM
koulninja's Avatar
Default Re: Can't get oil pan out... rusted exhaust bolts...HELP
Yea I got the old oil pan out and the new one in but man did I get greased up. It was like I went swimming in a pool of oil. Fun...lol.
I had to remove the bolts connected to the catalytic converter and take the exhaust manifold off. That way I was able to drop the old oil pan out. I put some liquid gasket on the oil pan and gasket and it was good to go.
But now a new problem. Radiator is old and leaking so needs to get replaced. Going to the auto store tomorrow to pick me up a new one plus new hoses. One problem fixed then a new one arrives. Go figure...
Old Jul 31, 2011 | 09:52 PM
B serious's Avatar
You really shouldn't put any liquid gasket all the way around the oil pan and oil pan gasket. You've just sealed that motor shut lol.
Old Aug 1, 2011 | 05:46 AM
turbodcxbro's Avatar
I always use a light coat of hondabond on the oil pan gaskets, keeps em from seeping oil like they are notorious for. Never a problem here..
free_money
Oct 21, 2014 08:33 PM
Aseegz
Aug 9, 2013 03:03 AM
codye3m
Oct 28, 2008 08:55 AM
vectorsc
Mar 31, 2008 06:26 PM
Civichatch1993
Mar 15, 2005 05:56 PM
