'91 CRX SI d15b1 to '00 d16y7
Old Jul 30, 2011 | 04:21 PM
Nitsuj's Avatar
Icon6 '91 CRX SI d15b1 to '00 d16y7
Need to know whether it can be done, how difficult it is, and what the sticky details that I need to look into would be. I've hardly ever touched Hondas and have limited experience with engine swaps as it is but enough aptitude to follow instructions and enough friend support to make it happen. Any info is appreciated.
Old Jul 30, 2011 | 05:09 PM
project91crxsi's Avatar
Default Re: '91 CRX SI d15b1 to '00 d16y7
it can be done, i had a y7 in my 91 crx dx. your better off putting a vtec head on it tho before you put it in
Old Jul 30, 2011 | 06:26 PM
KINGVEM^^ED6's Avatar
i did this swap this year make sure you go mpfi and get a y8 z6 or a6 intake manifold
since your going y7 make sure you use z6 or y8 headers they are longer if you use your
stock b1 headers they will sit on the oil pan and shake your exhaust if you have any
other questions shoot me a pm
Old Jul 31, 2011 | 12:16 PM
Nitsuj's Avatar
In terms of just getting the car up and running with the materials from the civic straight to the crx, what problems am I going to have? I'm against a wall and need the transportation asap so right now I'm just looking to solve the immediate complications and worry about the finer details and a better build in the near future. Thanks again.
Old Jul 31, 2011 | 01:46 PM
since the car is mpfi you should be able too use your stock header and intake manifold
just to get it up and running just bolt that **** up to the y7 block
Old Jul 31, 2011 | 02:51 PM
NOFX's Avatar
H-T White Ops
Good to know that it'd be relatively easy to put my '98 D16Y8 into my '88 HF if I ever wanted to (I understand I'd need a cable tranny from an '88-'91 Si though).
Old Jul 31, 2011 | 08:11 PM
you'd have to convert to obd1 so you can run vtec
Old Jul 31, 2011 | 08:22 PM
NOFX's Avatar
H-T White Ops
Totally okay with that. Thanks.
Still sort of toying with the idea.
Old Jul 31, 2011 | 09:08 PM
Canadian_EF's Avatar
Drive-way swapped D16y8 into a DX hatch, it's pretty straight foreward. IAT needs to be relocated, fan switch wires need to be extended, dizzy wiring and injectors, swap drivers side post mount.
couple other little things, but it's an easy swap. i'm so ready for B-series now.
Old Oct 3, 2011 | 03:19 AM
19EF90's Avatar
So i am doing d15b1 with z6 head but wanted to just drive the stock b1 around,So i put on a6 intake mani and dizzy on and my car is already mpfi,it wont start ant ideas, help for anyone would be hella cool been trying to get running forever now.
Old Oct 3, 2011 | 04:20 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Everything you need to know is in here...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
Old Oct 3, 2011 | 09:38 AM
19EF90's Avatar
thank you for your info,also wondering is it much harder to convert from obdo mpfi to obd1.
Old Oct 3, 2011 | 11:00 AM
DO IT ON ALL FOURS
Not at all... all that information is there as well - even more further down and in later posts...
Old Oct 6, 2011 | 01:24 AM
19EF90's Avatar
okay cool cus ya i cant seem to get my car running i have fuel,spark,timing good.
I putt a6 cam in my b1 head but still no fire up any ideas please help?
Also i did the valve lash to the a6 specs is that right?
Old Oct 6, 2011 | 02:34 AM
19EF90's Avatar
no nothing i have not checked its like i just cant get the timing right.
Old Oct 9, 2011 | 04:54 AM
19EF90's Avatar
so have tryed everything i can think of, car just wont fire,i have checked timing and fuel went to check spark funny thing only getting it in cylinder 3 and its only getting that spark on that 3rd cylinder hole on dizzy. i know sounds crazy but i can change any plug wire to number 3 hole any wire and it will spark but none of the rest will any help would be greatly appreciated thank you to any one who can help me.
also i checked main relay and dizzy wiring even thou car is mpfi never know lol just losing my mine trying to find a way to get her to run.
JdmRex25
Jun 30, 2009 11:00 AM
GiMpInThaCiv
May 30, 2006 10:42 AM
N2HIFI
Apr 7, 2005 06:28 PM
drjondurst
10
Jan 8, 2003 08:51 AM
drjondurst
Jan 7, 2003 12:56 PM
