For those understand Electronic diagram
Old Oct 2, 2002 | 06:25 PM
iam7head's Avatar
Default For those understand Electronic diagram
http://home.insightbb.com/~niedejb/pics/o2drawing.gif
here is it, pardon my lack of eletronical skill.
can anyone tell me what should i do?
really confuse because the picture and diagram look a maze to me..
Old Oct 2, 2002 | 07:09 PM
Archidictus's Avatar
Unceasing Measure
Default Re: For those understand Electronic diagram (iam7head)
i can't even read that horrible picture...nor do i know what it's for so, no, i cannot help you at all
Old Oct 2, 2002 | 08:41 PM
iam7head's Avatar
That's what i was thinking too until i found the enlarge/zoom thingie.
take a look again for me yeah yeah? thx
Old Oct 2, 2002 | 08:42 PM
the DR.'s Avatar
whats your question?
Old Oct 2, 2002 | 08:47 PM
Mikey's Avatar
Default Re: For those understand Electronic diagram (CIVICtypeS)
Are you trying to measure the resistance of the O2 sensor (don't see why you would do this)?
or
Are you trying to measure the voltage fluctuation of the 02 sensor?
or
Are you trying to figure out how an O2 sensor works?
[Modified by Mikey, 11:56 PM 10/2/2002]
Old Oct 2, 2002 | 08:52 PM
tinkerbell's Avatar
OK, i understand electronic circuts and the two things in the box joined with green dots are a capacitor and a resistor.
these two componants when used in conjunction with each other form a filter circut.
this circut will only allow a certain range of frequency to pass through the circut (you bass and treble ***** on your stereo are similar)
so i guess it is trying to modify the O2 signal sent to the ECU and trying to tell it something is different...
dunno what, maybe you could enlighten us on what it s for?
t..
Old Oct 2, 2002 | 09:06 PM
iam7head's Avatar
Default Re: For those understand Electronic diagram (tinkerbell)
Oh...my dumass forgot to ask the real question...
Iam confuse with which wires to solder with all that stuff.
so i know two resistor for both wires and join them together with the
capacitor?
Old Oct 2, 2002 | 09:10 PM
tinkerbell's Avatar
solder the 'black' wire to the capacitor
solder the 'grey' wire to the resistor
solder the other capcitor leg to hte other resistor leg and then solder the capacitor and resistor legs to hte ECU wires.
just like hte diagram.
t..
Old Oct 2, 2002 | 09:11 PM
tinkerbell's Avatar
or use a simple board to hold the componants and solder the wires to that...
maybe goto radio shack and ask for assistance...
t..
Old Oct 2, 2002 | 09:39 PM
iam7head's Avatar
Just clear up everything for me...thank!
Old Oct 2, 2002 | 09:45 PM
iam7head's Avatar
one last question..
I cant find any 1.0uf tantalum 35v DC
can i use a 1.0uf with 50v?
Old Oct 2, 2002 | 09:47 PM
tinkerbell's Avatar
as long as it is a tantalum,
the voltage rating is MAX volts it can do... so it will be OK,
t..
Old Oct 2, 2002 | 10:13 PM
iam7head's Avatar
how can i tell is tantalum? I really have no idea or what so every about those thing
again..so I can use a tantalum 1uf in any volts?
sorry to be annoying but yeah...thx
Old Oct 2, 2002 | 10:19 PM
tinkerbell's Avatar
tantalum are more expensive because they use higher grade materials, ie tantalum
it should look like a grain of rice i guess, or more like a small plastic bead with two legs,
eg
you should use 35V or higher...
HTH,
t..
Old Oct 2, 2002 | 10:27 PM
iam7head's Avatar
and 1uf only right?
thx
Old Oct 2, 2002 | 10:28 PM
tinkerbell's Avatar
yep, the 1uf is the value of the "capacitance",
the voltage is the maximum voltage rating of the componant.
t..
Old Oct 2, 2002 | 10:45 PM
iam7head's Avatar
http://www.imagestation.com/album/?i...ulation_page=Y
can you check if my "plan" are going to work or not..
Old Oct 2, 2002 | 10:56 PM
tinkerbell's Avatar
looks good, use proper shrink wrap!
t..
Old Oct 2, 2002 | 11:01 PM
iam7head's Avatar
just solder both resistors, still have to look for the capacitor in another radio shack.
So i can find the shrink wrap in radio shack too right?
thank, dude! you been really helpful!
for you
Old Oct 2, 2002 | 11:02 PM
tinkerbell's Avatar
no probs, go and spend some cash at Radio Shack
cheers,
signing off now,
t..
Old Oct 3, 2002 | 06:10 AM
DonF's Avatar
Default Re: For those understand Electronic diagram (honda_tech408)
Looks like its time for that GED.
Old Oct 3, 2002 | 08:02 PM
iam7head's Avatar
Default Re: For those understand Electronic diagram (DonF)
is that it? someone actually did the bypass told me that the sensor only set off the warning light and it have nothing to do with running lean/rich...
BTW i am talking about the sensor for the oem cat.
So what can i do the bypass that sh_t?
Old Oct 3, 2002 | 08:07 PM
tinkerbell's Avatar
all you mother ***** is a dumb ****
here is wat that picture say
the o2 sensor is input sensor to your ecm dat control your fuel amount to push into ur car
o2 determance how much fuel is add or take away from the car
that picture saying dat if you modify the sensor and put a resister to the "input" to ecm u will fool ecm to add more fuel or watever you want it to do by increase the resistance in the circuit or decrease it. o2 sensor volts. 0-1, 1=rich condition .50 volt lean. .so on .......
post reported to moderator.
t..
Old Oct 3, 2002 | 08:09 PM
tinkerbell's Avatar
its cool, the cat O2 sensor is used to monitor hte condition of the cat converter itself, and will set a code if it is outside set parameters.
it seems that this circut will ensure that the O2 sensor does not send signals beyond these parameters...
i hope it works
t..
Old Oct 4, 2002 | 05:49 AM
fuguman's Avatar
New User
omg are u guys still wondering what that is
why dont u go on his site and find out
he has some cool stuff
