clutch pedal sticks to the floor
Hey guys i changed the slave and clutch master cylinder to day and started to bleed it and took out all the air and the clutch pedal still got stuck on the floor so i took the cmc out and bench bled it and still did the same thing i been bleeding it for the past 1 1/2 hrs and its still to the floor. Can some one give me an idea of whats going on?? Thanks
is there any clutch fluid leaking anywhere. follow all the lines and also look inside under the dash to see if the clutch master has a leak. did you use a new seal on the cmc?
