How'd you wire your JDM motor?
Old Oct 2, 2002 | 06:11 PM
fOmaNPu's Avatar
Default How'd you wire your JDM motor?
How'd all of you end up wiring your engine? Everything is for RHD, and this is prolly gonna be the biggest bitch of my install.
Old Oct 2, 2002 | 06:13 PM
Kamin's Avatar
Default Re: How'd you wire your JDM motor? (fOmaNPu)
use your stock harness and run the necessary wires.
you have to.
its very difficult to use the jdm harness.
[Modified by KAMiN, 7:14 PM 10/2/2002]
Old Oct 2, 2002 | 06:28 PM
poison's Avatar
Default Re: How'd you wire your JDM motor? (KAMiN)
merge your stock harness with the jdm harness
Old Oct 2, 2002 | 06:37 PM
Nameless RB26's Avatar
Default Re: How'd you wire your JDM motor? (poison)
convert teh car to RHD. lol
B18c5: 99-00 Si harness, ctr ecu
Old Oct 3, 2002 | 12:29 AM
hondaZvic's Avatar
Default Re: How'd you wire your JDM motor? (Nameless)
yeah RHD!!!!!! u would have major props from alot of people i think.
Old Oct 3, 2002 | 12:45 AM
Tofurky's Avatar
Default Re: How'd you wire your JDM motor? (hondaZvic)
wiring is the suck *** of all suck asses...
if there was a magical way to use the RHD harness.. it would save you many headaches.
like stated before, use your stock harness, and add on parts from the jdm harness. it sucks, but gotta do what you gotta do...
Edit: you have an si, so it won't be that bad, your harness already has vtec.... damn yous
[Modified by Ruckus138, 9:46 AM 10/3/2002]
Old Oct 3, 2002 | 07:31 AM
pennies_hatchie's Avatar
Default Re: How'd you wire your JDM motor? (Ruckus138)
i dont know about you guys, but when i was wiring my harness (si, eg) to my b16a(j-spec), i didnt need to cut or splice anything. everything fit perfectly, i guess im just lucky!! good luck
Old Oct 3, 2002 | 07:46 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: How'd you wire your JDM motor? (pennies_hatchie)
No cutting here either (I even used the JDM engine wiring harness). And since using the P28 the only other problem I had was getting a USDM vtec solenoid. I don't need to run any additional wires.
GMR*Spork
Jun 3, 2006 11:47 PM
street95civic
Aug 22, 2005 08:23 AM
phthalo
Jun 18, 2004 10:45 AM
nutsack
Oct 26, 2003 05:04 AM
Tofurky
Aug 29, 2002 09:41 PM
