Hesitation and sputtering after installing Y8 harness
Just installed a fresh new y8 harness on my obd2 jdm d15b w 3stage vtec with p2j ecu. After installing it, it finally started up. But there was one problem thought everything was ok till i hit the road to go back home. Engaging it to first i would step on the gas and around 2 - 2.5k rpms it would sound like there was a rev limiter but it would go past and everything would be ok. then when i would switch gears there would be a lot of play room till the gas hit again and it would jerk. also even if i release a bit from the gas the car would jerk as if i was downshifting to very high rpms and when i press on the gas again a little bit after releasing it would jerk.
Hopefully this isnt confusing...
So i finally fixed this problem. i had to do the 3 iacv to 2 iacv. But after doing this, a new problem raised. fuse 41? the one for my pmfgi keeps blowing. What could be the cause of this? i spliced the 2 wire plug onto a 14 gauge wire then to the yellow and blue wire. Would the 14 gauge be allowing more power in causing the fuse to blow?
dctegls
Oct 4, 2010 05:04 PM
chickenwing
Nov 15, 2008 06:30 AM
bigwill_2004
Jul 27, 2007 09:19 PM
