car broke down & will not start
Old Oct 2, 2002 | 05:45 PM
dinosa21's Avatar
Default car broke down & will not start
I lit my friend drive my car once and it brakes. This is the problem the engin will turn over but is not getting spark or purging gas. I checked all the relays and all fuses. I checked to see if its gitting power from the ignition and is. Im clueless. help please
5th gen civic
[Modified by dinosa21, 6:47 PM 10/2/2002]
Old Oct 2, 2002 | 05:50 PM
.Beaver's Avatar
Bloody Beaver
Default Re: car broke down & will not start (dinosa21)
what model civic is it?
Old Oct 2, 2002 | 05:55 PM
97hb's Avatar
Check the ignitor in the distributor.
Old Oct 2, 2002 | 06:07 PM
dinosa21's Avatar
Default Re: car broke down & will not start (97hb)
its a dx. from canada
Old Oct 5, 2002 | 07:12 PM
PnX-R's Avatar
Sheesh.. Why does everyone always say to check the distributor.?.. You said that the distributor is getting power. And I believe you. But here's another question.. How much power is it getting.?... It needs at least 9.6volts.. And if it's not getting 9.6 volts.. Your battery either has a low charge or is in the process of sulfation.. Meaning it's not putting out enough amperage to turn the starter.. Have a shop do a load test on the battery and load it to 130amps. If the battery can put that out, your battery is still ok. Hope that helps a bit.. Let me know how it goes..
agiorlando
Aug 16, 2010 10:21 AM
Domnificent
Apr 19, 2010 01:59 PM
Jap_Spec_Imports
22
Sep 11, 2006 07:15 PM
thashadow
Jun 18, 2003 10:11 AM
thashadow
Jun 17, 2003 09:35 PM
