friends car wont move....need help
Old Oct 2, 2002 | 05:39 PM
91cvcsi's Avatar
Default friends car wont move....need help
my friend replaced the leftside axle on his 91 accord last night and the car drove fine last night and this morning but then he was driving this afternoon at 25mph and then it seemed like he let off the gas and the car would just rev.....he got it towed home and when he puts it in gear it just revs and the speedo goes up but the car wont move....when the car is off and in gear it wont roll but when he pushes the clutch in it will roll..he replaced the rightside axle and it didnt fix the problem....anyone have any ideas? TIA
Old Oct 2, 2002 | 06:00 PM
Chiovnidca's Avatar
Default Re: friends car wont move....need help (91cvcsi)
Is the left side axle properly installed? Is the inner joint fully seated in the tranny?
Old Oct 2, 2002 | 06:04 PM
91cvcsi's Avatar
Default Re: friends car wont move....need help (Chiovnidca)
yes that has been checked 3 times
Old Oct 2, 2002 | 06:13 PM
Chiovnidca's Avatar
Put it in gear and see what's spinning and what's not. Since the speedo is moving, you know the diff. is turning, so that leaves it to the axles. What's turning, what's not?
Old Oct 30, 2002 | 06:30 PM
garagespecial
Guest
Posts: n/a
maybe the forks in the tranny is lose.....but id check to see if the axle is seated in the tranny
Old Oct 31, 2002 | 02:24 AM
niedejb's Avatar
Default Re: friends car wont move....need help (garagespecial)
Sounds like the axle is broken at the tranny. Seen it on a friends hatch. The axle end that mates with the tranny is broken and it just spins in the tranny.
Looks ok from the outside cause the axles still where it supposed to be. Pull the axle and it has no splines cause there still in the tranny.
dirvin7588
May 11, 2011 11:43 AM
dthug
Feb 14, 2007 03:43 PM
t0ekn3e
23
May 15, 2005 06:44 PM
1hotintegra
Oct 14, 2002 11:26 PM
darkfx
40
Sep 16, 2002 04:34 PM
