92 Civic Si - rev, hesitation, and backfire issue
Old Jul 28, 2011 | 12:41 AM
Eg6_k20's Avatar
Default 92 Civic Si - rev, hesitation, and backfire issue
Hey.
Bro I been going insane trying to find out an issue I'm going thru for the past 2months. I been looking at ALL of posted up threads.
° I recently changed my map sensor, that wasn't my issue.
I have an issue with my accelaration. It chokes between 2000-3000 RPM. Acceleration drops down as if it was to turn off. Then it will pick up on acceleration as if it was a delay. It acts up in & out of gears.
Pretty much my acceleration drop back down at 2000-3000 RPM & picks back up & backfires while passing 3000rpm. I can't explain, maybe I can text, email, or call to demonstrate the sounds.
I have done all my work on my car as far as putting the motor in & connecting all accessories. Car turns on & idles perfect & low just the way I like it.
I got a 92 Civic Si hatch.
• full stock 2004 PRB Type-S 6spd swap w/ harness.
• no harness cutting.
Issue is at Part throttle, not full throttle. Check with video, maybe you can make it out. I just had my boy record it real quick but he went all extra on the recording.
Check it out....
http://youtu.be/HUIA1mnoxMI
Old Jul 28, 2011 | 06:04 AM
Former User's Avatar
Default Re: rev issue
Do a tune up and check the ignition timing. CEL codes?
Hondaguy83
Dec 13, 2012 12:02 PM
Eg6_k20
Engine Management and Tuning
Sep 7, 2011 01:01 PM
Jeanious
26
Mar 28, 2007 04:31 PM
