Help Quick???
when doing an b18a swap in a 1990 Si what harness do i use, the one from the b18a or the one off my d16a6???
As far as I know, all of the wiring should work with the B18A's injectors, ecu & distributor.
I've never done the swap though... Check out http://www.hasport.com they do a little outline of most B-series swaps.
[Modified by MrTodd, 11:21 PM 10/2/2002]
Well if the b18a is all obd-0 stuff.. you use the injectors off that along with your si harness and the Ls computer... then you drop the motor in with some sort of mount kit... there should be no wiring with the ls... especially since you have an si.. theres all the info u need
PDRIFT86
Apr 11, 2007 09:20 PM
HtC_SiR
May 26, 2004 12:11 PM
