Tansmission Swap
I have a 96 4dr with a manual transmission and I have a 00 2dr with an automatic transmission.
I'd like to swap the transmissions, anyone know how or what all needs to be done to make it work?
Wiring harness the same?
Pedal swap?
Axels work?
Sensors the same?
Pedal swap?
Axels work?
Sensors the same?
Assuming your going Auto trans to manual-----
Parts you will need:
- 92-00 D series manual tranny
- 96-00 master cylinder, nuts
- 92-00 D series slave cylinder, bolts
- 96-00 manual pedals, connecting pin
- 96-00 clutch lines, or the Earl's conversion ss braided clutch line
- 92-00 shift linkage, bitch pin, bolts, bushings
- 92-00 shifter, ****, dust boot
- 92-00 rear transmission manual mount
- 96-00 D series rear transmission manual bracket & bolts
- 96-00 passenger side tranny mount
- custom passenger side tranny bracket
- 92-00 D series Flywheel & Pilot Bearing
- 92-00 D series Clutch & Pressure Plate
- 92-00 D series Release Bearing
- 92-00 D series Manual Flywheel bolts (auto ones are too short)
- 92-00 D series lower front tranny bracket & bolts
- 92-00 D series manual starter & lower long starter bolt
I have a 96 Civic 4dr D series manual, can I just swap all the parts from that?
Randomnoob
Aug 13, 2018 08:39 PM
